Mick,
Think you are right
so with the pump running constanly I've two MVs in the airing cupboard. Please can I ask what checks I need to do to confirm that they are in the right position as demand requries.
Now we are getting somewhere, as I mentioned earlier I did not have the manual for this boiler at hand. You now state that you have two MVs, so the first thing to do is look a for lever on these valves, which could be situated on the sides or the end of them. They will be sticking out from a slot, and at either end of this slot will be marked Auto and manual. Check to see if you can move these levers back and forward along this slot with no resistance, with hot water and central heating switched on, and again with the hot water and central heating off. usually with the hot water cold and the central heating cold the levers should be in the AUTO position. It would be a great help if you could identify the make and model of these valves complete with any numbers that they have on them ie, Honeywell 4073A etc. This would also help to trace the wiring.
