I have the above boiler which is working fine, except that the LED display panel has gone blank. First thought is to leave it alone, except that if it does develop a fault I will be unable to view any fault codes. Can someone point me in the right direction.
If the boiler is functioning correctly it may be worth checking that the ribbon cable connecting it to the PCB has not become disconnected otherwise a new front panel will be required
