I have a He24 combi boiler , recently the hot water pressure has dropped from any tap in the house, the water temperature is fine it flows but at a lower rate than it was whihc makes showers abit uncomfortable etc..
The burner remains on and no fault codes displayed. The CH works Ok aswell.
How do you clean the bolier with X400? What could be the most likely part causing the DHW pressure to reduce?
Any help much appreciated.
Thanks Mike
Thanks Mike
