Hi all,
Had issues with our Ideal Isar HE30 Combi Boiler about 10 months ago, plastic diverter cartridge part no. 174200 needed replacing as when you ran the hot taps, the radiators were getting hot.
Struggled to get a plumber at the time to do it and basically since then the hot taps have been fine but to have a shower you put the central heating on otherwise it doesn't get hot enough. Anyway I've been meaning to get it looked at and serviced but been very busy with work and it's just got put off until now!
Noticed some water underneath the boiler Friday evening but thought it was from around the sink, cleaned it up and then was making tea Saturday evening when water started coming out of the bottom of the boiler - quite a bit of it!
Turned boiler off straight away on front panel and also turned it off at the mains fuse. Put buckets/containers underneath, quite a bit of water trickled out and every now and then it drips a little.
Took the case off to see where it was coming from.. PCB and electrics all look OK i.e. they don't appear to have got wet.
The water seems to have been dripping from the top part of the case (the one with the additional cover), there is a hole with grommet and some wrapped wires on the front left hand side; it's coming out of there, and also on the rear left hand side, the very back corner there are a few drips.
The front right hand side has a thin white tube going upwards, this has white deposits around it where it goes into the top part of the case (limescale)? there is also some wires going upwards into this part and they have limescale around them, more than I remember and bits of this were loose on top of the controls below.
Basically just after some advice please, as to what the problem might be, what it should cost to have it fixed.. how much I'd expect to pay for a proper service of the boiler..
There is also an old gas pipe that goes from the cellar to one of the upstairs bedrooms that I'd like cutting and capping off.. how much would I expect to pay to have this done?
Also we have two gas fires, what should I pay to have those checked?
Also had issues with some radiators lukewarm/cold at bottom, others not getting as hot as some.. not great at all.
Also will add, installed under Warmfront in 2007, last serviced July 2010.
Thanks in advance!
Thanks in advance!
