Hi all
recently the boiler is doing what can only be descibed as backfiring. It will blow the flame out, then relight 3 times before showing the error code L-F. Reset it and it will fire up again with no issues then run for a while before backfiring again.
It will fill a bath with hot water with no issues and heat the house for a while before the backfiring starts again.
In the last couple of weeks its had a new PCB, ignition electrode and gas valve, could it be the diverter valve now?
The condensate pipe is clear also.
Thanks in advance of any advice as to what the problem could be now
Cheers
Cheers
