I have an ideal mini 24 boiler that loses pressure almost instantly once filled. All our pipes are above the floor and i can detect no leaks, all valves are tight and no aparent leaks. When i bled the radiators upstairs they were quite low and the water seemed fizzy. The ones downstairs didnt take much bleeding and the water flowed as normal. I pressed the shrader valve on the expasion vessel and only air came out, quite high pressure. I placed a sandwich bag over the outlet pipe that comes outside, i left it over night and no water was in it.
Does anyone have any ideas of what the problem could be or any other checks i can make?
Thanks in advance.
Mike
Thanks in advance.
Mike
