Hi Chaps,
I hope everyone is keeping safe.
I went to bath my little boy this morning to find there was no hot water.
I thought my igniter board in the S24 boiler had finally given up (it was hit or miss and sometimes needed a smack to get the boiler to ignite).
Swapped the board, fired the boiler up only to find it was still the same, no ignition.
great, flicked the dip switches to find an error code if (faulty primary circuit - no water or absence of flow)
When I activate the hot water, I hear the hive receiver click, the zone actuator move and the light shows on the boiler and there is the usual pump wurr/splashing noise which then stops, the green light continues to flash as normal to indicate its working. But nothing is happening.
water pressure was at 2.7 so I used the release valve behind the pump to drop pressure but it has continued to keep releasing water without me having it twisted, a small rate of flow but I can hear it dripping and watch the pressure gradually drop. Anyway, not to worried about that, I think it eventually stops.
Are there any tips or advice on things I can check to get this going? Is the pump dead?
thanks!!
Mark, smelly son and moaning missus!
thanks!!
