Ideal Response 80!! Intermittent ignition
19 Dec 2007
Hello, my boiler has been tempremental of late. When the CH is switched on from cold it doesn't light sometimes taking several attempts. One way to get it to light would be to turn the hot tap on which would light the boiler then select CH on. After that it is fine until the next 'cold start'. Today though the turning hot water trick didn't work so I had to resort to special language, it eventually lit using the CH switch.
Now then, I was thinking of replacing this boiler in the summer but I'm not sure if it'll get that far but I don't really want a boiler change this time of year.
Any ideas what the defect maybe and if it is worth fixing?
Cheers
Well this afternoon it switched on fine when HW demanded but wouldn't ignite when CH selected on. I guess I'll see what the gasman says if I can get one round, just I don't want to flog a dead horse.
any money spent of this boiler is wasted.
live with it and bring the change forward as much as you can
If you really must repair it then a set of electrodes ,a spark generator and a damn good service will usually resolve ignition problems. Personally I would scrap it. Its a piece of junk.
Did you get this resolved?
My Ideal Response 120 is doing the same thing!
