Hello
My Ideal Response 120 gas combi boiler will not ignite the central heating from cold first thing in the morning.
The CH light is on correctly and the boiler is whirring (the fan?)
If I turn off the mains and on again and then turn on the hot water tap it ignites, sometimes second or third attempt. It is then fine until the next morning including the central heating so seems to be a problem only from absolute cold.
You can see the ignition light flicker at point of ignition but not 'take hold'
The ignition has not locked, the pressure bar is always kept about 1.8 cold, no sign of leaks in the fan or HE, and the electrodes were recently cleaned at a service.
Is this a gas valve problem, an ignition problem or a exchanger problem?
I want to try and get another 3 years out of the boiler (7 years old) since I want to disrupt all the kitchen only at the next full refurb.
Many thanks
Many thanks
