Indesit IDL530 Dishwasher wash & drying light flash, It does not appear to have enough water in the cabinet, I checked for leaks (none), good water pressure to the inlet, cleaned inlet filter, checked wire on front panel to dispenser dish. Any help please
Led 1= Prewash / 3hr
Led 2= Wash / 6hr
Led 3= Rinses / 9 hr
Led 4= Drying / 12hr
LED. illuminated
1 = Overflow ( water in base )
1+2 = Pump timeout, or Software recognition error ( timer not programmed, wrong keypad)
1+3 = Circulation pump not working
2+3 = Not filling
2+4 = Heating circuit not working
2 = Solenoid valve 'broken'
3 = Thermistor (NTC) cicuit not working
4 = Temp not reached whilst heating ( poss NTC detached from casing).
It is usually necessary to 'reset' the machine after a fault code has been displayed.
Resetting.
Switch dishwasher OFF, rotate the selector switch to STOP/CHANGE and switch on, after a few seconds the LEDS will go out enabling a new programme to be selected.
