Looking for some help & assistance:
The water in our Indesit WD12UK, washer drier has stopped heating up. I assumed it was probably the heating element, however I checked it for continuity & resistance, and it seemed ok. I then checked power to the element when it was on a hot cycle, and there's no power going to the element.
I cant see any obvious fuses, and it looks like the supply cables head into the PCB, although I've not looked too far. I suspect it could also have been the thermostat, however I've been told when they pack in, its more likely to overheat?
I cant find a wiring diagram or manual for the machine anywhere, and wonder if someone out there can assist with what might be wrong, or point me to a manual?
Is there there's anything else I could check?
Thank you in anticipation.
