I don't see the point in paying over another £100 for a cylinder if a cheaper one will do the job. However, if you can tell me a factor of having a direct over an indirect I'm all ears as they say.
You can use a longer immersion with no coil. Most places have direct cheaper, try a different supplier.
Hi. I need a direct cylinder . However, I found the indirect cylinders are cheaper. Would it make any difference if I just got an indirect one and didn't use the coil connections?
