quick question ref to a mixer shower
i have uneven pressures at the cold and hot in the bathroom, i.e. cold water enters direct from the mains and hot is supplied via a tank in the loft. the cold has extreme pressure in comparison to the hot so i am not sure whether connecting both to a mixer will be of any practical use.
my question to anybody who is able to answer is: can i T off the cold water supply enetering the bathroom, add some form of pressure redcution device to this and then connect to the mixer keeping the hot water pipe a direct connection? this will ensure i have even pressure at the mixer. what types of pressure reducing devices can be used? can i use a ball valve, a stop tap, a gate valve or even a service valve? or do i need to implement a device like this:
http://www.screwfix.com/app/sfd/cat...HZOCFFI?productId=85889&imageNo=null&ts=63699
if the above is the only possible option, why is it favoured over the ones mentioned above?
