Hello all,
I've got the problem that when I run the hot water tap my Alpha 240E fires up as expected and then starts to deliver hot water normally. Just as you start to get the hot water coming through the boiler shuts off the burners meaning the hot water stops. Then 10 seconds or so later fires it up again...
Cold - Warm - Hot - Warm - Cold - Warm - Hot etc.
I assume this is a pretty common problem as a combi in my student flat did the same (landlord was too tight to get it fixed - although fitted an electric shower instead! )
Any help would be appreciated!!
