Intermittent hot water upstairs
5 Aug 2012
Buckinghamshire
Hi all,
this is my first post and I'm not a plumber so please bear with me.
I've got a problem whereby if I run the hot water upstairs it runs for a bit, nice and hot and then after a while it slows down to a trickle and then runs out completely.
If I leave it alone for a while the hot water comes back but the same thing happens again.
The hot water comes from a Megaflo cylinder and downstairs as far as I can tell is unaffected.
Any thoughts or advice would be VERY much appreciated as I don't really want to call a plumber but if I don't have a choice then that's the route I'll need to go and our 2 year old may have to have a bath downstairs tonight.
There is a filter on the cold feed to the cylinder thats probably blocked, not a job for the faint hearted or inexperienced.
Many thanks. Do you think I'm OK to leave the Hot Water switched on or should I turn it off until someone's been to look at it?
Turn off the hot water, its easier to work on a cold cylinder.
