I'm a newbie, but have been surfing this forum for some time. Well I registered so I must think it's good, very good to be fair.
Does a 40>32mm reducer exist to fit inside the 40mm pipe?
I need to reroute a short run and the existing 40mm pipe is in a tight spot, I can't get a straight connector in to weld in a normal size 32mm reducer.
I'm assuming there's no way to 'undo' a solvent joint? I believe the whole idea is that the plastic is now as one.
