I am a bit worried about my house electrics. When my plumber friend fitted a new central heating/hot water on demand arrangement a while back he had to cut the main water pipe. Once cut he noticed a spark across the joint and received a shock from it. Putting a meter across the gap it showed about 80v. I went around the house disconnecting stuff from the sockets (I run a lot of PC equipment) and the figure dropped a few volts at a time.
I take it this is known as earth leakage? Is it normal or should I get someone in to test the electrics properly. The weird thing is I never known a fuse blow at the fuse box?
Any advice would be gratefully received, I don't want to put my wife or myself in any danger.
Thanks,
Glen
Thanks,
Glen
