You have answered wrong post. Seems there was a post asking about edging on skirting boards, don't know were it went?Laminate trim?
Scotias & floor trims | Flooring supplies | B&Q
Add the finishing touches to your home renovation project with floor trims and Scotials at B&Q. Order online or check stock in store. Open 7 days a week.www.diy.com
from Link?I can't see from picture, I got three wall lights 2 at £2 each and one at £4 from Link and I will admit even if not exactly what I wanted, at that price I was not going to argue. They have no PIR, so £4 one with integral LED comes from a smart 13 amp adaptor, and the two will bulbs, used smart bulbs.
Main thing is ensure water can get out, near impossible to stop water getting in, when it rains it cools the lamp so air contracts and will suck in water, so just ensure it can get out again.
I used silicon sealant at top, but not at bottom. View attachment 297561 this was the expensive £4 one, I used this View attachment 297562sort of thing to control it, the control cost more than the lamp.
May need an extra terminal for the Live Loop if the connection block supplied with the lamp is only 3 terminals for Switched Live, Neutral and Earth.Any new light fitting will be supplied with a connection block for the wires.
Unlikely that anything extra would be needed.
Unlikely an outside light would be three plated.May need an extra terminal for the Live Loop if the connection block supplied with the lamp is only 3 terminals for Switched Live, Neutral and Earth.
That's undoubtedly true, but ones with a PIR quite commonly have a S/L as well as a permanent L.Unlikely an outside light would be three plated.
Those with an integral PIR tend to only have the one phase termination so the PIR is only on when the switch is on (or quite often can be overridden by switching off and back on quickly).That's undoubtedly true, but ones with a PIR quite commonly have a S/L as well as a permanent L.
Some do, and probably increasingly so, since the PIR's now probably directly control an ELV feed to the LED. However, the traditional ones (particularly pre-LED) usually use(d) a relay to switch LV, in which case the "S/L' was usually made available - both to feed other lights and, in the other direction, to allow manual control of the light(s) (if on-off-on functionality was nlot built in) - andThose with an integral PIR tend to only have the one phase termination so the PIR is only on when the switch is on (or quite often can be overridden by switching off and back on quickly).
