I own a flat with communal heating which is an absolute nightmare. I think I must be at the end of the loop because if anyone else in the building tinkers with their lock shields or opens up their valves fully, I get less heat. Right now, I've measured the average room temperature at around 13 degrees when the heating is on 'full'. But with the cold weather due tomorrow, that will drop even further.
The agent who runs the building says I can't have my own gas supply as it would cost too much to have all the pipe work installed. I'm completely fed up with the situation.
Can anyone recommend an alternative way of heating up the property other than oil and convection heaters which are very expensive to run? Are electrical boilers any good these days?
