I think you will start to get black mould coming through the grout lines in the near future where water has got behind the tiles. Patch it up for now and you will have to suck it and see, could all be fine on the other hand.
Ignore the plaster board you can see, its fine. Looking at the original close up pics, I still reckon what's behind those tiles is fecked & what you see is just the 1/3 tip of the iceberg. Filling repairs on what you can see are only going to give you a breathing space, what's festering behind there is still going to carry on & if it doesn’t smell already, it certainly will do at some point.
You might as well try joe’s car body filler, it'll probably last longer than plaster/filler if you can get it to stick.Sounds promising... so how do I go about patching it up?
I'm more than happy to try filler but there is nothing to fill. There are no holes, just missing paint and exposed plasterboard.
i need a new pair of glasses i could have sworn that was a hole if all you have is missing paint and the boards are sound just scrape back the loose paint then apply easifill over damaged area and rub down till it is level with the paint then repaint
So is that not block work I can see; I thought it was plasterboard dot & dabbed over blocks
Perhaps I need to borrow Steve’s new glasses
Looks like dot-dab over p/board to me.
Easi fill or one coat to patch.
Why use car filler?
It's waterproof. When all else fails it's the best bet. It's impervious to water and takes paint well. That's why you don't use Easifill on your car - it isn't tough or waterproof. I use it for a thousand jobs around the house. Best kept secret in DIY. If you don't want a good tip - then that's up to you.
