The house was rewired in July and the pendant (normal type) in the dining area of the kitchen/diner is 3.2m from the edge of the sink so hopefully this is ok regarding safe zones?
I have another question - would adding a connector block to the light (to facilitate connection) be part p notifiable as in it may be deemed to be a "permanent change to exisiting wiring"? or am I reading too much into it
a pregnant partner is better than a pregnant widow. Be careful, even if the shock doesn't kill you the fall of the step ladder could put you in hospital.
There is absolutely no problems with the light fittings you have mentioned concerning IP ratings, other than the one that is installed out of the window.
We have gone through this before on another thread, I think. Something about 6.00mm cable that could be 2.5mm or even 1.5mm.
If so, that's fine as the connection was made within the fitting and accessible.
