Hello all, I'm joining two 15mm flexible pipes that have the compression nuts on the end as part of the fitting (to receive 15mm copper pipe)
I want a full bore cutoff valve in the middle (compression fitting).
Is there any other way of joining this all together without 2 short lenghts of 15mm pipe either side of the cutoff valve?, ie join the valve directly to the pipe flange with a special olive or fitting?.
No problem if not, it would just make the job a bit neater.
Cheers all!.
Cheers all!.
