I would fit
two 28kW Broag combi boilers (they are cheaper than the 24kW system boiler). They are better quality than Vaillant and much cheaper. A well priced quality boiler and they have a superb control system, superior to W-B and Vaillant.
http://www.avantaplus.co.uk It is well priced and the combi DHW section need not be connected ( a combi is a system boiler with a water section). With two boilers you have backup and one can be off in summer, saving wear.
Or connect the DHW and have it as backup and isolated by a 1/4 turn valve, or connected just doing the showers only, to give high pressure from the mains. 56W of instant DHW may be all you need, and then you can get rid of the DHW cylinder if one there.
The Broags have integral weather compensation. I would have this connected up using the outside sensors and have both boilers set the same and connected to a low loss header. Off the header have the system split into zones with TRVs on each rad. One Grundfos Alpha Smart pump will do and a zone valve for each CH zone. After the pump have a flow switch and this is the control interlock. When all TRVs are closed, the flow switch switches out the boilers. No stat on the floors, just 4 cheap simple timers.
If you have a DHW indirect cylinder heated by the boiler, have this off the low loss header. It is a case of the cylinder stat switch a relay. This switches a 28mm "diverter" valve, so all heat goes to the cylinder. The relay can switch out the CH pump, but need not to as it is a smart pump. The cylinder stat connection on the boilers each go to a set of contacts. This ramps the boiler heat to maximum to give a fast DHW reheat. When the cylinder is satisfied the diverter valve moves over to CH and the boilers revert back to outside weather compensation control, giving excellent condensing economy.
If using a cylinder, only in deepest winter will two boilers need to be switched on. The summer boiler can alternate each year to reduce and even out boiler wear.
Do you heat your (Domestic Hot Water) DHW via the boiler using a cylinder?
Two 28C Broags are just under £1,300. That is with the integral weather compensation, which lowers and raises the radiator temperatures to the outside temp and saves gas. W-B and Vaillant do not have this as standard, and W-B not at all.
http://www.tradingdepot.co.uk/DEF/c.../Central Heating Boilers/Broag Remeha Boilers
The control options:
http://www.avantaplus.com/docs/Issue 5 -Avanta Schematics Booklet.pdf
See this thread also:
//www.diynot.com/forums/viewtopic.php?p=1075974#1075974
