Kitchen socket failed after wiring in new oven
If you know for sure the socket is on a different circuit ,no point checking the fuse on the cooker circuit
If I switch off the oven at the board, everything else still works. Maybe the socket or switch has just died, but seems odd that it was working until I swapped the oven over.
Well I don't know what the hells going on. I tried switching the dryer on when I got home from work, and now everthings working again.
Just checked the back of the oven anyway, had the faceplates off and there's no way I could have disturbed any cables.
How can an outlet not work for two days, then start working again?
I'm getting an electrician in just to check everything, but all outlets and switch panels are fine from what I can see.
Now that it's working again, can you confirm whether the dryer is on the cooker circuit?
Well the electrician came out yesterday and checked everything.
Oven nothing to do with tumble dryer
Checked oven and tumble dryer sockets, switches, fuses
No fault found, everything safe
Mystery!
