Lagging CH pipes
4 Jan 2006
Yorkshire
I know CH copper pipes that run in unoccupied areas,loft/roofspace cellars etc should be lagged but I'm not sure if pipes that run under groundfloor floorboards should be. The floor is suspended about 3' above the ground so I would have thought the pipework would suffer heat loss. On the other hand would the heat coming from the pipes aid the heating as I think it does between floors.
Although heat rises, very little of it will get through the floorboards, underlay and carpet to make any difference; most of it will just heat up the surrounding air.
Insulate the pipes, preferably with Waterboard approved insulation, which is larger diameter.
Thanks for reply, was my assumption that pipes under upstairs floorboards correct or should they also be lagged.
Pipes in the void between a ceiling and the floor above are not usually lagged.
Radiators are designed to make large the ratio between outside surface area and internal volume of water. Tubing is pretty much the opposite, so it's best to insulate it - that way as much heat energy as possible reaches the radiators.
