Hi guys, just need a quick check off you if possible please.
Doing the final checking of the existing wiring before the LABC come round and I discovered that the landing light set-up in my house doesn't seem to conform to any of the diagrams I can find.
The upstairs and downstairs switches are wired as per the 2-way diagram ( albeit with no red sleeving over the switched lives ) but the upstairs and downstairs lights are fed in parallel off the upstairs ceiling rose and hence, the same mcb on the existing CU
Is this OK or should the wiring be changed to the two lamps controlled by two way switches diagram in the reference section ?
Thanks as always.
FORGOT TO ADD>>>>>>I will be adding an intermediate switch for this lighting circuit once I've got the go-ahead from the council, will this make the wiring any different ?
Thanks as always.
