Laying laminate on the top of Lino
16 Sep 2004
Leeds
Is this generally an acceptable thing to do? The lino would act as an extra layer of insulation?
Also, the floor of the kitchen is concrete, would the lino act as a suitable DPM or would I need to add a plastic sheet as well?
Can anyone recommend any cheap laminate floor stockists as well. We are 'tarting up' our kitchen, the laminate will probably be replaced in 3-4 years anyway.
TIA
Is it lino that is on the floor? - this is normally fully stuck down - or is it cushion vinyl? You can install on lino or vinyl (depending on condition) but it is better to remove it - more hygienic for one thing.
You should put down a dpm and underlay - combi foam type is better.
I wouldn't recommend any cheap laminate I'm afraid.
