Hi All,
Forgive me in advance for my info-graphic pedantry. I would like to get this right - so I am preparing.
As per image above, the bathroom is quite compact (1.8m x 2m) and the basin and toilet are on this window wall as is the bath end (when the bath goes in).
The new bath can be 515mm - 535mm height which means that I should be able to get the run around the bath at full tile and also get flush with the window on a full tile. Also, the basin should be pretty much on a full tile.
I will be tiling the lower half of the wall fully (aside from behind the bath itself. The sill and reveals will also be tiled.
Does this look ok? I am assuming that it's best to go for less cut tiles around features?
Also, the walls have been freshly plastered - so I am right in thinking we need SBR bond (as a bonding coat or primer?) rather than PVA?
Thanks for any advice!
