Leaking monoblock kitchen tap
13 Aug 2007
Help Mono block swan neck tap leaking eventually removed it & tried to take it apart removed tap heads & cerclips even small grub screw at the rear but try as i might, the swan neck would not detach from the base.
1)does it detach. or is it a sealed unit.
2)are there o rings or washers inside.
3)do i have to break the bank and pay the ridiculous price for a new (gold) tap thats if i can find one.
4)or is it another visit to the gym to improve my strength then curse & swear until i separate it.
After you have removed the grub screw from the body try rotating the swan neck ninety degrees from the centre left or right - if you can do this whilst trying to lift the neck from the body you might be able to find the release position.
There are usually a couple of 'O' rings at the base of the swan neck
Good luck !
Good luck !
Cheers newboy raring to go next day off iam on to it.
dynomo said:
//www.diynot.com/forums/viewtopic.php?t=40899
See if this dated post helps..
Thanks for the link dynomo, when i get to see the gubins i will check out the pics.
