See the valve circled in blue.
I am not sure what this valve is and which way it should be. This is the one which is going in to hot water tank and the other end is joining the pipe between pump and divertor valve.
Its leaking since I turned it in an attempt to fix my other CH issue. Now its turned clockwise full and is leaking drops of water. The danger is that the leak is right above wiring cabinet. I am thinking I should have never touched this valve. Is there some sort of sealant I can use. Which way should it be turned ?
many thanks for any help.
