I have a need to install some wall lights in a kitchen and for various reasons cannot access the 5A radial lighting circuit. Is it permissible to take a spur from the 15A ring main (which I can access) provided that it has a 5A fuse and switch incorporated. There will be 6 x 20W low voltage tungsten and 6 x 20W slimline fluorescent lamps connected along the spur. Also can I assume that the total current drawn will be approximately 1A (I have read somewhere that fluorescent lamps must be over-rated when doing this sum). Many thanks for your help.
