I have loop in at the light fitting, not the switch. I also have bar spots with a rather small base so when I need to take the light fitting down for decorating it's a pain to put back up keeping the cables tucked away inside safe.
Can you get something a bit more streamlined than your typical connector block, that goes into the ceiling void (without having a massive hole for something like the Click Flow connectors) with only a flex coming from that, through the light fitting hole then wired in? Cable is 1mm T+E but even that requires the bigger connector blocks getting 3 wires in to a single terminal.
Something similar to crimping connectors, but detachable for maintenance without having to dewire anything!
