Lincoln LGD 25/35 warm air unit
13 May 2004
Cambridgeshire
Can someone tell me where to find parts (lint filter) for this warm air heating unit? I understand Lincoln were taken over by someone............ Any ideas anyone?
Nearly all warm air units are now managed by Johnson & Starley in Northampton (?)
Tony
Lincoln were american units J&S do spares which might fit, dont hold your breath though they're more likely to try and get you to fit a Brink.
Lincoln are well over 30 years old prob coming on for 40 . As per your previous post a pair of tights will grab most of the dust but johson starley should be able to supply a sheet of filter material
I emailed Johnson & Starley and they say they do not have spares for Lincoln. And yes, Mum's unit was fitted in 1974! I have emailed back to ask if they do sheets which I can cut to size - presumably other units have similar types of filter??
J & S say they have two types of filter I can cut to size - foam or material.
I'm not sure which I want. I can only describe the original filter as a very lightweight synthetic material which you can rinse out gently under the tap to clean it without it falling to bits, but is it foam or material??? I can't think of anything that is similar to help describe it. Would it matter if I used the wrong type anyway?
I had already Googled Lincoln warm air prior to this post...............
Can't see anything of help.
Am I missing something here???
FFS.just get a bit off foam and use it as a filter, heater is ancient and you are not going to get right bit
The first site google brings up after "sponsored link" is a company which advertises it services Lincoln warm air heaters. Ask them for a filter.
