Got a call about a leaking waterpipe that could not be repaired because it was live.
Tested it, and sure enough 55 volts on it.
Checked CU, (split load 1 rcd) feed from what looked like 16mm2 t&e, 2 10mm2 y/g disappearing in the floor, presumably to water and gas but could not inspect as the floor could not be opened.
Turn main breaker and n-e goes from 55V to 6 V.
Breaker back on and n-e back to 55 v.
The more mcb's I turn off, the lower the n-e, but 3 in particular (10-20 volt each) and the rest just 1 or 2 volt difference.
the flat was created by a developer who split up a house into 4 flats, and after that disaster it was "improved" by a builder.
Anyone got some pointers where to start looking, or is it a typical case of disconnect and test/inspect the lot?
I am qualified to work on electricity, but my corebusiness is heating and this one puzzles me somewhat
