I can't find a drain point for the lower part of my heating, there's one on in the airing cupboard but that's upstairs! The ground floor is wooden and the pipes come up from it so I imagine if there is a drain point it must be under the floor, is there a convention for installing drain points that will give me an idea of where to look? there's lots of tiles/laminate in the way so I really don't want to have to rip too much up! Failing that I guess I'll have to loosen a radiator downstairs and drain as much out of that as possible and/or open a pipe under the floor (which I will be doing anyway and is why I need to drain) and drain the leftovers into a small bowl or something.
I'm right in assuming that I must drain in order to move pipework, there's no way of sealing the feed from the tank and using capiliary action etc to keep the water from flowing out is there? I guess in someways it's a pointless question as I'll be putting TRVs on most of the rads at the same time.
