I have lots of questions.
Extension of an existing lighting circuit -
Can one run two sets of 4 x 50w downlights off a radial extension from the lighting circuit on 1mm T&E.
for the switch the wiring will be less than 50mm below the surface but within the safe zone, does this need earthed conduit to protect it?
The cable will be attached to the joists above 100 mm of insulation below 150mm more, is this acceptable?
Extra sockets
Please can you confirm that i am ok to run 3 Double sockets on a spur with a 13a FCU protecting them.
Actually thinking about it i could split the ring at the back of a double socket, replacing it with a single then extend the ring around this new room, are there suitable single gang accessories for this purpose?
Also I believe all of this work does not need Part P as it is an extension of an existing circuit which is permitted.
I am also planning on putting in another spur on the ring in another location that originates from the kitchen but terminates in another room, would this be notifiable?
Extra sockets
