B barkie1 Joined 4 Jan 2011 Messages 284 Reaction score 22 Location Durham Country 11 Jan 2011 #1 as title. Topped it up still get a trickle out the lets thought might have been frozen so been checking over last few weeks no change? Is the pump knackered? Do you think that could be due to freezing? Car is a hyundia accent r reg
X xr4x4 Joined 1 Oct 2009 Messages 3,159 Reaction score 301 Location Hampshire Country 11 Jan 2011 #2 i had the same problem on da bimmer.. turns out theres a filter on the end of the pump which was blocked.
C Crickleymal Joined 2 Nov 2010 Messages 256 Reaction score 15 Location Gloucestershire Country 11 Jan 2011 #3 Could be a number of things. Blocked jets. Even if you poke them with a pin they may be blocked inside. Should be easily removable to clean. Blocked piping. Pull the pipe off the jet and see what happens Split piping. More likely if it froze. Blocked filter as someone else said. Duff motor/pump. Pull pipe off jets and see what happens.
