I don't know what Tony means when he says you can't have two pressures, that is what a PRV does. It was invented for that purpose.
Its not possible for the same pipe system to have 1 Bar downstairs and 3 Bar upstairs or vice versa!
Who said anything about a 'same pipe' system? The downstairs tap could be straight off the mains, and upstairs (tank and subsequent shower) fed via the PRV.
Mathew
The output of an UV cylinder can ONLY be lower! Never higher!
The kitchen tap should be connected directly to the mains supply. ( It makes a good point for measuring the pressure part of a dynamic flow rate measurement ).
Tony
Something odd about an outside tap apparently giving 4 Bar.
