Hi everyone, thanks for reading. I am about to convert a 21" wide door (1st floor airing cupboard) into a 36" door (2x 18" doors).
This will involve widening the existing. I will be checking with building regs etc to see if the wall is load bearing or not, but thought it worth posting the question here beforehand, as there is alot of expertise around!
My current thought process is to isolate the lights and power, cut the brickwork, maybe add a lintel above ? then make the door good. I've included some pictures.
Feedback would be welcome as to whether the wall may be load bearing, and whether a single to double door should be tackled in a certain way.
Thanks in advance. P.S. Double doors will allow for better access to cupboard, and make the cupboard slightly deeper, in order to install a larger water cylinder.
Before:-
Desired look After work is complete:-
Picture of loft floorspace above wall:-
Turning left (in loft), picture of roof joists above, which have the same distance below chipboard:-
Before:-
