You're wrong. It has been tested using multiple randomised studies and it doesn't work.But it does not need to, and that is the thing which will come out eventually and prove to everyone that the august journals you quoted in your other post, and in which you place so much blind trust, are lying to you.
Watch my lips, metaphorically.
Hydroxychloroquine is one of the safest drugs known to man, it has been used for 65 years and given to people of all ages, and it is known to be safe, that is not up for debate because there is scientific research going back years to prove it.
Hydroxychloroquine is very effective against covid when given as a prevention, and when used early as a cure.
Vitamins C, D and zinc are also effective as a prevention, good levels boost your immune system.
Ivermectin is also a safe and effective drug for covid, as is Budesonide.
They are the treatments that are being used widely in Africa and India, and are probably the main reason why those continents are not drowning in covid cases or covid deaths.
In fact, if you look up most of the African death rates on worldometer you will find that they are a fraction of those in the so called civilised world.
If you people were not being lied to by the governments and media you place so much trust in you would know all this.
You will come to know all of this eventually, and then you will realise the extent of the lies and the extent of the con.
There is no need for some experimental 'vaccine'.
There is no need for lock downs, masks or social distancing, other than as a means to control people and to make the people themselves want the phoney vaccine.
Nor is it risk free, long term use is tied to heat attacks and you need to be monitored for your retinas dissolving. That's on a low, preventative level of the doses. If you go with the very high, and they were incredibly high, doses used in the studies then you get a significant increase in cardiac death and no improvement in your Covid-19 symptoms.
Plus the nausea isn't fun at all.
And for the cherry on the cake, it is a 65 year old drug, the testing for side effects back then we're very rudimentary.
