Morning all just thought i would post some maths home work for you all to work out as i dont have a clue on how to do it.
Bit complicated and not sure if this can be calculated but here goes?
If a property is supplied with 3 bar cold mains water pressure what flow rate would that give you at the tap in litres per minute?
As i assume you should have at least 3 bar cold supply of water pressure on entry into the property?
