Maths puzzle four
E
EddieM
WARNING: This one is a shocker.
This was posted on the forum a while ago, I don't think it got a mathematical answer, unsurprisingly.
ok,
You have a cube of wood (it's actually irrelevant what it's made of) measuring 10cm x 10 cm x 10 cm.
you drill a perfect 1 cm hole all the way through between top and bottom vertices of the cube.
What percentage of the material is left?
Ow!
Break them down into layers 10 x 10 is 100 you drill top to bottom so take 1 off each layer which leaves 99. In effect 1% from each layer makes 99% of the whole cube.
Well no, cos across the vertices in 2D is sqrt 10^2 × 10^2 and that's just in 2D. This drill bit is going across opposing vertices in 3D.
Do you know the answer or just telling me I’m incorrect? From the question I believe my answer to be correct.
No I don't, I believe it is a very complex mathematical problem. With all respect I'm not sure you have understood the problem fully, however you could be correct.
So to try to rationalise.
A 10x 10x 10 cm3 cube would be 1000 cm3
A 1cm perfect hole drilled from 2 opposing faces would be
3.1415926 x 1^2 x 10 = 31.42
So the amount of material removed in that very simple example would be 31.42 / 1000 = 3.142%
I think the answer is approximately 98.68%.
Vortex to vortex is the hypotenuse of a rectangle triangle 10 x 14.14 (sq.rt 200) which is 17.32 (sq.rt. 300).
Not sure how to calculate the corners until the drill is all in so just knocked off 0.5cm.
so 0.5² x Pi x 16.82 = 13.2 cu.cm. so 986.8 cu.cm. remaining = 98.68%
