I thought that modern Consumer Units with DIN rails were designed to some sort of standard measurements, so you could use any MCB in any CU. However...
I have a Proteus split load CU with Proteus Incomer and RCD, and DETA MCBs. This CU has only the top half of the DIN rail - where the bottom part should be is flat, and the bus-bar forms the mounting for the bottom part of the MCBs.
Looking to add another circuit (a job I started last year, naturally ) I have looked at various makes of MCB and most of them don't fit! Wylex looks like it may be OK, but MK, MEM and Merlin-Gerin seem to have too little clearance for the busbar at the bottom, making the MCB sit too high, with the "island" with the switch on it too high up to go through the slot in the lid of the CU.
Added to which some MCBs have the fixed part of the DIN clip at the top, others at the bottom, which means the location on the top half of the DIN rail can be a bit unconvincing.
I've also noticed that RCBOs vary in design, with some having the RCD section added at the top of the unit, others at the bottom (so these can't be used with a bus-bar).
Now I have little experience with modern CUs, so should I stick to using all components from the same manufacturer? (Seems to negate the point of the DIN "standard"!)
Or is there any "common knowledge" which says that Brand X is tolerant of others' parts, Brand Y only really works with their own parts, and so on?
I'm not terribly impressed with the Proteus CU, so I may change it if there's a better made, more tolerant make, and I'm open to suggestions!
Cheers,
Howard
Cheers,
Howard
