I'd suggest getting some good quality, VDE certified ones.andrew2022 said:if you do decide to replace the MCB, i would suggest you get some cheap, insulated screwdrivers.
I think the DMM will be fine. If it's verified to be working immediately before, and when turning the main switch off causes all the lights to go out, all the appliances to stop working, and the DMM shows the bus-bar as dead, I think it's safe to assume that it really is dead.Spark123 said:Not to say it isn't safer to use a DMM than a volt stick (yuk) or a neon screwdriver (even worse, should be banned), a DMM is still not a recognized tool for testing dead. Recognized testers such as RS 410-0097 conform with the british standard and are permitted for testing dead.solderer said:Jaymack, i know its a bit off the original topic now, but why do you say it isnt safe? I dont have copies of the hse docs. The meter I have is CATIII rated, double insulated, 600v. It is marketed at electrical testing.
I've used it for testing the lighting circuits (other occasions) and found it very reassuring to know for sure the circuits are off. Far safer than common DIY alternative which is using a volt stick or neon screwdriver(!).
Cheers.
70s/80s vintage, possibly - so it could easily be a Type 1, which would have been 5A, not 6A.HDRW said:Since you said the MCB is 5A I assume it's a plug-in replacement for a rewireable fuse.
Solderer - Howard is right that you need to be cautious, so turn off the CU main switch, carefully remove the cover and see what's what.
Or beforehand tell us what the CU is, and/or post a photo, someone may well be able to reassure you about what you'll find inside.
