Just a quick safety question. Having turned off a circuit at the consumer unit via the MCB for that circuit e.g. a ring main or a lighting circuit - is it safe to work on that circuit e.g. adding another socket into the ring? Obviously haven taken steps to ensure someone can't accidently turn on that circuit again while your working on it!
I ask becuase from what I can see the MCB only isolates the live wire - the neutral is still connected to the block and other circuits will still be live?
Of course I could turn on the CU at the main two pole isolator but then that takes every circuit out which is a pain but which I'll happily do if there is a real risk in only isolating via the MCB.
ta.
ta.
