460mm to the edge of the gas hob and then 760mm directly above. However if manufacturers instructions specify otherwise use the measurements th MI states.Normally from floor to top of wall units is 2120mm and if you have standard 720mm wall units and 900mm to your work top from the floor this measurement is always achievable.
Lee
