I am posting this here and in the plumbing forum, as it is going to be a problem related to one of these areas.
I have a Mira Sport...I think it is a 2006 model. It was already installed when I bought the house, so I might be wrong. Looking at the sticker, it might be a 1995 model?
On the sticker at the top of the shower it says this: Sport 9.0 J95B 39/06
Anyway, yesterday it stopped working. It has a string pull, ceiling power on/off switch.
When the power is on, the shower light only comes on when the power button on the shower is in the off position. When it is pressed in, the light goes out. Whether the light is on or not, the shower doesn`t work....no water spray at all.
I replaced the shower with a brand new one, but nothing had changed. I took the shower off the wall, and attached some copper pipe to the supply to check for water flow, and it was fine.
I read the fault finding section in the new showers booklet, and it suggested the electrics could be the fault....a break etc.
I cut 2 feet off of the supply cable, and replaced the load cable entirely. Still no joy.
So what do I do next? If I replace the supply cable entirely and it still doesn`t work, what then?
HELP!
Thanks.
David MacDonald
HELP!
Thanks.
David MacDonald
