MK CU 11yrs old Model?
Discussion in 'Electrics UK' started by AndyPRK, 10 Mar 2012.
  1. AndyPRK
    4 Jan 2009
    2,948
    Thanks Received:
    273
    Herefordshire
    Country:
    Could someone tell me what model this CU this is please.
    I am thinking about buying a couple of 6A RCBO's and want to know which ones to get.
    Do MK do Type C RCBO's ?
    [​IMG]
    MCB's labelled 59xx
  2. AndyPRK
    4 Jan 2009
    2,948
    Thanks Received:
    273
    Herefordshire
    Country:
  3. Taylortwocities
    28 Jul 2006
    16,117
    Thanks Received:
    1,550
    Oxfordshire
    Country:
    The current models of RCBO will fit that board.
    Probably the ebay type is OK as it looks modern.
    Before you rush off to do this do take the cover off the CU and see if there is LOTS of space as the RCBO is much taller than the existing MCBs.
    How will you test these RCBOs? Do you have an RCD tester?
  4. Lectrician
    18 Jul 2004
    8,165
    Thanks Received:
    351
    Devon
    Country:
    Ignore me!
  5. RF Lighting
    31 Mar 2006
    18,917
    Thanks Received:
    1,183
    Leeds
    Country:
    The best thing to fit in that CU would be Schneider RCBOs.
    The are a different name on the front, but made by the same people who used to make circuit breakers for MK, the type that you have in your CU.
  6. JohnD
    15 Nov 2005
    44,000
    Thanks Received:
    1,962
    Perth
    Country:
    who said that? :confused:
  7. AndyPRK
    4 Jan 2009
    2,948
    Thanks Received:
    273
    Herefordshire
    Country:
  8. RF Lighting
    31 Mar 2006
    18,917
    Thanks Received:
    1,183
    Leeds
    Country:
    • Thanks Thanks x 1
  9. Lectrician
    18 Jul 2004
    8,165
    Thanks Received:
    351
    Devon
    Country:
    Exactly my mistake RF, Merlin and Square D Scnieder MCBs will fit, but not the RCBOs! Hence my 'ignore me' comment!
    • Thanks Thanks x 1
  10. AndyPRK
    4 Jan 2009
    2,948
    Thanks Received:
    273
    Herefordshire
    Country:
    Ok thanks RF. What about the one in my 2nd post with the small test button at the bottom. Do they fit well?
    RF recommended: with top test button
    7932S ?
  11. RF Lighting
    31 Mar 2006
    18,917
    Thanks Received:
    1,183
    Leeds
    Country:
    They do fit ok, but they don't match your existing circuit breakers, and IMO are not as well made as the old schneider ones were.
    • Thanks Thanks x 1
  12. AndyPRK
    4 Jan 2009
    2,948
    Thanks Received:
    273
    Herefordshire
    Country:
    Out of interest, how easy is it to fit a 2nd RCD and convert the CU to dual RCD on this board? e.g fit an N block and bus bar ? THere appear to be 2 MCB's that aren't required.
  13. RF Lighting
    31 Mar 2006
    18,917
    Thanks Received:
    1,183
    Leeds
    Country:
    To be fair by time you've messed about and bought all the bits RCBOs will be as cheap and you end up with a far superior installation.
  14. AndyPRK
    4 Jan 2009
    2,948
    Thanks Received:
    273
    Herefordshire
    Country:
    I guess I should buy a B32 RCBO too, and move an important circuit over to the other side. I think I can free a slot up, as I assume the RCD position is fixed.
    Thanks for your help RF.
Loading...
Share This Page
