Mk701 shaver socket
11 May 2013
Hi all. I have a MK K701 shaver socket which comes with safety isolating transformer attached to back of facing. Just wondering if this can still be installed within zone 2, as transformer is within facing and not installed outwith zone 2.
Yeah it does - has that BS number on the back of shaver socket. Cheers for your help
Thought as transformer is with terminals it would still be classed as in zones, but guessing I am mistaken. Cheers.
As an electrical accessory, a socket outlet, it is.
But the transformer part is not, and I thought that was what you were worried about.
Do you mean that below the surface of the wall is not within any zone, or what?
No, it's not, otherwise people might find themselves bound by Zone regulations in WCs, bedrooms, passages and so on. Zones stop at walls, and the transformer in a shaver socket is not accessible without using a tool.
So are you suggesting that one can put any accessory in any zone of a bathroom provided that it is recessed a millimetre or two below the surface level of the wall?
Kind Regards, John
Simply in a recess below the level of the surface of the wall around it, no, unless the surface of the wall happens to be right on the boundary of Z2.
In a recess with a cover which requires a tool to remove, yes.
Simply in a recess below the level of the surface of the wall around it, no, unless the surface of the wall happens to be right on the boundary of Z2. ... In a recess with a cover which requires a tool to remove, yes.
Hmmm. Maybe I've misunderstood. I thought that the OP was concerned about the transformer which was part of his 'shaver socket', and which attached to the back of the face plate of that accessory (which he suggested was "not without Z2"), and that (by answering "yes it is") you seemed to be suggesting that (even if the accessory was 'in' zone 2) the transformer which was an integral part of that accessory would not be. Have I misunderstood?
Kind Regards, John
No, you have not misunderstood.
The transformer which concerned the OP is not in Z2.
No, you have not misunderstood. The transformer which concerned the OP is not in Z2.
I'm having some difficulty in understanding your point. Are you saying that, although the face plate of the shaver socket is (presumably) in Zone 2, that the components which form part of that accessory are not? ... and, if so, what is the significance of that (given that you couldn't have the transformer without the face plate)??
Kind Regards, John
The significance is that the OP was concerned that the transformer is in Z2.
It is not.
Why he is concerned, IHNI.
The significance is that the OP was concerned that the transformer is in Z2. It is not. Why he is concerned, IHNI.
I see. Don't you think that your response to his questions/comments about his concerns will have simply confused him?
I also would imagine that, even if it doesn't have much/any actual significance, a good few people would probably disagree with your academic argument that the 'back parts' of a flush-mounted accessory are not in Zone 2 even if the face plate is.
Kind Regards, John
