L
liam999uk
Basically as posted. Can it be done without problems in the cold weather???
Cheers
Cheers
You can but put anti freeze and rapid hardener through the mix.
If it drops below zero through the night it will bleach the mortar as well.
You shouldn't do 'wet' work in temps three degrees or less.how low we talking?
what do you mean by bleach the mortar?
Its not just a case of covering it with hessian which would help but then you have the problem of the wind blowing it off. As from 2014 latest regs for new roofs stipulate mechanical fixing now.
